tscheuerman
Could not access network location "" error during uninstall
When I attempt to uninstall a previously successfully installed application, I encounter a 'Could not access network location "" ' error. I've review the Uninstall MSI log file and do not see the cause of this issue.
I've attached the following files:
- The AI project file.
- The Install MSI log file.
- The Uninstall MSI log file.
You will not be able to run the actual installer as it is dependent on a Tomcat and Java installation.
When running the installer, my application is successfully deployed and a Tomcat service is successfully installed and started. Any suggestions on how I can address the uninstall error would be appreciated.
Thanks in advance,
Todd
MSI59CF.LOG
Install log file.
(679.79 KiB) Downloaded 187 times
InterQual Connect Server 1.80 Tomcat 9.0.64 Testing.aip
AI Project file.
(176.35 KiB) Downloaded 224 times
MSI4f6f0.LOG
Uninstall log file.
(132.35 KiB) Downloaded 169 times
Re: Could not access network location "" error during uninstall
Hello Todd,
That might be happening because on uninstall, the "JAVA_FOLDER" property - which is used to create a property based folder - is empty.
From what I can see in the .AIP file, you only set that property during install:
