mpande
.net 6 Runtime prereq skipped on Server 2008 R2
We have a site running Windows Server 2008 r2. Our installer has the following predefined prerequisites checked:
.NET Runtime 6.02 x64
.NET Runtime 6.02 x86
ASP.NET Core Runtime 6.02 x64
ASP.NET Core Runtime 6.02 x86
On running the installer the site appears to flash the prerequisite screen for an instant with no options, and a next button, and then the next instant will go to the screen to install our product, never actually installing .net 6.0. I'm attaching a log file where I ran our installer, and then cancelled the install once presented the choice to installer our software.
Running the .net 6.0 installers manually addressed this issue, but this will be an issue as we need to deploy an upgrade of our software, which changes our software's platform from an older version to .net 6.0
How can we address this?
MSIB0F0.LOG
(83.21 KiB) Downloaded 258 times
Re: .net 6 Runtime prereq skipped on Server 2008 R2
Hello Max,
This happens because the Windows Server 2008 R2 is not selected by default on the "Supported Windows Versions" field of the "Install conditions" tab:
server 2008.png (67.46 KiB) Viewed 5491 times
And this is because these prerequisites are not supported on this operating system:
not supported.png (53.17 KiB) Viewed 5491 times
Even if you check the above "Windows Server 2008 R2" option, the prerequisites installation for ".NET Runtime 6.02 x64/x86" will fail.
As I can see, only the "ASP.NET Core Runtime 6.02 x64/x86" can be installed on this OS. You can check the above option for them.
