NigelShaw
Replacing file on uninstall
Tue Aug 09, 2022 5:03 pm
Hi
During an install, i need to update a dll file but upon uninstall, i would need to replace it again with the original. How can i set that up?
NigelShaw
Re: Replacing file on uninstall
Tue Aug 09, 2022 5:27 pm
I can also store a copy of the original in the same location and upon uninstall, rename the file to its original name
Wed Aug 10, 2022 12:18 pm
Hello Nigel,
Indeed, a solution would be the one you presented - to rename the original file so it is not overwritten and on uninstall to rename it back.
Another solution would be to copy the original file into a different location and then copy it back on uninstall, after the files were removed.
