peterk
Add temporary folders via the command line
Thu Aug 11, 2022 7:49 pm
Looking at: https://www.advancedinstaller.com/user- ... mands.html
There doesn't seem to be options to add temporary folders, only files. I cannot use the GUI to do this but have to use the command line. Ultimately, I am in need of adding a nested tree of folders containing files that will be loaded onto the system via a custom inline powershell script. Is there an option to do this that I am missing? If there isn't an option, does anyone have a workaround/script to manage a scenario such as this?
Version 19.6 (BF52C98E)
Re: Add temporary folders via the command line
Fri Aug 12, 2022 11:38 am
Hello Peter,
I'm afraid it is indeed not possible to add an entire folder as a temporary folder through the command line as of right now.
However, I have already added this improvement quite some time ago on our TODO list and hopefully this will be implemented in a future version of Advanced Installer.
peterk
Fri Aug 12, 2022 11:53 am
What would be the suggestion then for achieving this goal then? Having a set of files within nested folders that I need to execute a custom action powershell script against? I am looking for solutions to work around the lack of functionality and its not clear to me what the best approach would be.
TIA
Fri Aug 19, 2022 9:36 am
Hello Peter,
The solution to this would be to first add the folder under the "Temporary" folder and then add the files as temporary files.
Mon Sep 19, 2022 5:32 pm
Hello Peter,
This improvement has been added in Advanced Installer 19.9, released on September 14th, 2022.
