This happens because the "Name" field of the Shortcut does not support formmated type properties.
This is a Windows Installer limitation and only PseudoFormatted properties can be used. Unfortunately, the Shortcut name field does not support Formatted properties. Only PseudoFormatted properties are supported and they are resolved at build time.
During the installation you need to use only properties referenced by Formatted data types, for example "[ProductName]".
More details on our
Windows Installer Formatted Type article.
Now, as a solution for your request, you can achieve this using custom actions (for example rename the shortcuts using cmd).
Go to the
"Custom Actions" page and add a new
"Launch file" scheduled like this:
- launch file ca.png (201.83 KiB) Viewed 1528 times
Command line: /c "rename "[DesktopFolder]updater.lnk" "[EDIT_1_PROP].exe.lnk""
Note: Replace EDIT_1_PROP with your property.
Attached you can find a sample project.
