barryharrington
[APPDIR] not picking up user entered path for registry entries
When a user changes the default path for installation from the installation dialog the value is not being transferred to APPDIR when writing registry entries. Example: adding registry entry for vsto file to Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\Excel\Addins\RVI PC Imaging 9 with Manifest set to file:///[APPDIR]RVIOffice\RealVision.Excel.Addin.vsto||vstolocal results in the default APPDIR "c:\rvi" and not the entered installation folder "c:\rvi2". See attached for current settings. Is there a way to get the entered path for the registry entries?
Re: [APPDIR] not picking up user entered path for registry entries
Unfortunately I'm not able to reproduce this using a sample project.
Can you please send us the .AIP (setup project) file and an installation log by email to support at advancedinstaller dot com so we can further test and investigate this?
You can create an installation log by launching your setup package with a command line like this:
msiexec /i setup.msi /L*V installLog.txt
when using an MSI package type, or a command like this
setup.exe /L*V installLog.txt
when using an EXE package type.
