a.guelle
Move to Feature from Command Line (AddFolder / AddFile) [solved]
Dear AI Team,
when I add a file or a folder via the command line, is it possible to move it to a specific feaure?
To which feature is it added by default?
Angelo
Re: Move to Feature from Command Line (AddFolder / AddFile)
Hello Angelo,
Your files are added by default under your current feature.
In order to set the current feature, you can use the following command line: /SetCurrentFeature <feature_id>
All new added resources (files, registry, etc) will be included in this feature.
AdvancedInstaller.com /edit MyProject.aip /SetCurrentFeature MainFeature
To create a a new feature you can check our New Feature Command Option article.
Therefore, you can set the current feature and then add your folder/file.
