thales.pereira
HRESULT: 0x8000FFFF (E_UNEXPECTED)) When uploading MSIX to the Windows Store
Problem description - When uploading the MSIX file to the store, it rejects the file with the error "Catastrophic failure (Exception from HRESULT: 0x8000FFFF (E_UNEXPECTED))";
How to reproduce ? Upload the file to the store, when setting up deployment.
Environment - See attached .aip.
Non-store installer works fine, it's just the store installer that we can't figure out how to upload without errors.
Any insights in how to solve this?
SitradProInstaller.aip
(324.25 KiB) Downloaded 197 times
Re: HRESULT: 0x8000FFFF (E_UNEXPECTED)) When uploading MSIX to the Windows Store
Hello Thales,
At a first sight, I can not say for sure why that is happening, especially because that error is thrown by Microsoft Store.
First of all, if I correctly understand this, the MSIX package builds without any errors and you can also install it?
If that's the case, please have a look over the following article which might be helpful in your case:
How to publish your MSIX package to the Microsoft Store?
If none of that helps, could you please try to upload from a different computer and see if that helps? Perhaps it's got something to do with your machine.
