cxf
Uninstallation is not possible when uninstalling [shortcut]
When I uninstall the installation package, there are two situations: 1. The [Shortcut] of the desktop cannot be uninstalled; 2. The [Shortcut] of the desktop can be uninstalled, but the shortcut of the program still exists in [Control Panel - Uninstaller] .
Re: Uninstallation is not possible when uninstalling [shortcut]
I'm not sure why this is happening.
In order for us to further investigate this, can you please forward to us by email to support at advancedinstaller dot com the following resources:
1. the .AIP (setup project) file
2. a download link for your setup package
cxf
My program exceeds 90M, and the upload fails.
TBox.aip.zip
(20.75 KiB) Downloaded 272 times
Thank you for your project.
Please note that I'm not able to reproduce this when I build your project with a debug version.
The application is succesfully removed from the Control Panel and also the shortcut is removed from the desktop.
As I can see from your screenshots, you have side by side installations. Are you able to reproduce this issue on a clean machine?
Most likely, your products have shared components. Please have a look on our Why files are left behind after package uninstall? article.
Basically, this means that your files are somehow shared between multiple setups.
I believe your setup will work as expected on a clean machine.
cxf
I did not find the corresponding [The packed GUID]
I'm sorry but I am not quite sure I fully understand the issue here.
If possible, could you please give me some more details?
cxf
【https://www.advancedinstaller.com/user- ... uestion240】
This post mentions that Product Code needs to be changed. After I changed it, I could not find the new GUID in the [HKEY_CLASSES_ROOT\Installer\Components] directory.
As mentioned in our article, the new GUID is manually modified for the components which are shared between multiple setups.
A packed GUID can be obtained by applying a transform to a standard GUID. This transform performs the following operations:
  • removes the curly braces and separating dashes from a standard GUID
  • writes each group of the first three groups of hexadecimals characters in a standard GUID in reverse order
  • switches every two characters in the fourth and fifth group in a standard GUID
Have you tested your setup on a clean machine as I said? This issue may happen only on your machine where you have multiple installations side by side.
Also, please note that you can click on the Change Product Code and component's GUIDS option in the Upgrades page. By clicking on this hyperlink you can change the Product Code of the package and the GUIDS of all its components.
cxf
According to the normal software uninstallation logic: after selecting [Uninstall], first delete the shortcut on the desktop, and then delete the [DLL] dynamic library.
However, the situation on our side is: after selecting [Uninstall], only the [DLL] dynamic library is deleted, and the shortcut on the desktop has no relevant operation traces.
Please check my previous replies. As I said before, I cannot reproduce this issue using your project. Most likely, this problem only happens on your computer because you have multiple installations side by side (and possibly a corrupt old installation).
Once again, have you tested your setup on a clean machine as I said?
