cxf
The runtime environment is not installed
Start the software exe file on the client computer. The first install works fine. The second time I switched the connected IP address, a pop-up window prompted that the runtime environment was not installed. Have you ever encountered this situation?
(My packager has 90M and cannot upload attachments, what should I do?)
Re: The runtime environment is not installed
As stated in the screenshot, your application requires .NET Core in order to run.
You can avoid this by installing .NET Core as a prerequisite with your setup.
Installing Prerequisites
cxf
The key question is here. Because I have already set the prerequisites. But still this prompt appears.
Is the prerequisite installed with your setup?
Additionally, are you sure that is the correct version your application requires in order to run? For instance, if in the error message you click "Yes", what version is downloaded?
If so, could you please forward me the following resources:
- a copy of your .AIP file
- a download link for your setup
by email at support at advancedinstaller dot com so I can further investigate this on our side?
