cogs33
How to check if a specific software is already installed
Hi all,
What would be the correct way to check if another software (same publisher) is already installed and then refuse to proceed with the installation?
Rationale: The product about to be installed would irreversibly alter existing installations of several predecessor products, so the installer must make sure no such conflict existis before installing. A warning message is supposed to appear, warning the user to uninstall said products first, or at least make a system backup.
As far as I understand, a Launch Condition can accomplish this?
I find the dialog for adding launch conditions a bit confusing.
How would an expression for this look like?
Re: How to check if a specific software is already installed
You can achieve this by using a Search and use the property as a custom condition in the Launch Conditions page.
Let's say we do not want to install our application when Notepad++ is installed. In order to achieve this, follow these steps:
1. In the Search page create a new search. For example we can check if the registry key exists:
2. In the Launch Conditions page click on the Custom tab and add the following condition: NOT RESULT_PROPERTY
Attached you can find a sample project.
You can also use a ProductVersion search since you know the Product Code of your other applications:
productversion search.png (29.88 KiB) Viewed 7008 times
You can also have a look on the Custom launch condition using extended search for registry key. forum thread.
launch condition.aip
(13.57 KiB) Downloaded 279 times
