Jaime
Delete Specific Files Not Created during Installation
Good afternoon,
I understand I can create a File Removal action for a file that would be created during installation. However, during installation, I would like to check if a file (not created during installation) exists in the target computer and deletes it if it exists.
Would that be possible?
With kind regards,
Jaime
Re: Delete Specific Files Not Created during Installation
Hello Jaime and welcome to our forums,
That should be possible, through a Custom Action.
For instance, first, we can create a "File Search" that will look for the file on the user's machine.
Let's consider we want to look for the following file: C:\test\test123.txt
We can create a "File Search", as it follows:
After the search is initially createad, you should right click on it --> "Add search location" --> "Folder"
After that, you can create a custom action that retrieves the path from the search and then removes the file. In addition to that, you can condition the execution of the custom action based on the search, so it executes only when the search succeeds.
