For the
Air Theme the watermark text is added on the images which make up the frame, located in the following paths: "C:\Program Files (x86)\Caphyon\Advanced Installer 17.0\themes\common-res\frame\breeze", "C:\Program Files (x86)\Caphyon\Advanced Installer 17.0\themes\common-res\frame\powderblue" and so on.
From the
Themes page you can change the background for your theme:
- background.png (162.04 KiB) Viewed 4677 times
You can use the background.jpg image located in "C:\Program Files (x86)\Caphyon\Advanced Installer 17.0\themes\air\resources\variations\white" or you can create your own background and change it.
