peterk
Add support for adding SQL Script File to command line interface
We have a need where we want to modify the list of SQL scripts that are run as part of the installer. The names of the sql scripts change frequently as they contain versioning information in the title. So we need a way of attaching SQL Script Files to a known database server connection.
So a command like the following to allow for automation:
advinst.exe /edit "myapp.aip" /AddSQLScriptFile "1.2.3-droptables.sql" -dbserver "SiteConnection"
Re: Add support for adding SQL Script File to command line interface
This is already on our TODO list of improvements. I have increased its priority and hopefully it will be implemented in a future version of Advanced Installer.
As soon as this improvement will be available we will notify you on this forum thread.
Until then, I am afraid the only way is to add the SQL script through our GUI.
This improvement has been added in version 21.1 of Advanced Installer.
Return to “Feature Requests”
