vinaysalian
Not to run restore scripts if database exists
Hello ,
Thank you for creating this wonderful application .
Scenario : during installation the installer should automatically check in SQL Server whether if the database exists. If exists skip running the restore script and just run the update script .
I have a created a Query for the same and saving the result in the DBExists_PROP and same returns TRUE if the database exists and FALSE or (null) if the DATABASE does not exist .( Using the Test Option we have tested the query and the same returns true or false/(null))
Then I am adding a condition to run the restore script only if the DBExists_PROP ="false" or DBExists_PROP <> "True" but still every time we run the installer the DB Is restored or replaced .during second install.
Kindly advise
Re: Not to run restore scripts if database exists
Thank you for your kind words! :)
Now, regarding your issue, that might happen because you are using a private property, as opposed to a public property.
Windows Installer Properties
Could you please try setting the property as public (all uppercase characters) and let me know if that helps? E.g.:
DBEXISTS_PROP
vinaysalian
Dear Catalin,
Apologies for the late response. Have been on weeklong vacation. I tried using property " DBEXISTS_PROP "all in capitals but still it restores the database even if database is present. The test of the query which saves the result in the property returns either a '1' or null. So, the condition which i am using is DBEXISTS_PROP = "false " or DBEXISTS_PROP <> "true" or DBEXISTS_PROP <> 1 in my Restore Script. None of these conditions work and the database gets replaced /overwritten if the database exist . Please let me know if there is anything else which needs to be done.
The query used to check if the database exists is as follows
-- Inline SQL script
USe Master
IF OBJECT_ID('dbo.CheckPersonnelDBExists') IS NOT NULL
DROP FUNCTION CheckPersonnelDBExists
GO
create FUNCTION dbo.CheckPersonnelDBExists (@dbname varchar(128))
RETURNS varchar(10)
AS
BEGIN
declare @result varchar(10) = ''
SELECT @result = CAST(
CASE WHEN db_id(@dbname) is not null THEN '1'
END
AS varchar)
return @result
END
GO
Select dbo.PersonnelDBExists ('Personnel') as DB_EXISTS
GO
This result we save in the property DBEXISTS_PROP
Testing the Query results in 1 if DB exists and Null in case the DB does not exist
Kindly advise
From what I can understand, you'd like to restore the database only when the DBEXISTS_PROP="(null)". Have you tried using this condition?
You set the property to either "1" or "(null)" but then use the DBEXISTS_PROP="false" condition.
If that doesn't help, could you please try to create a sample project reproducing this and forwarding it to me together with a test-case describing how I can test this so I can further investigate this on our end?
vinaysalian
Dear Catalin,
Thank you very much. As suggested ,Got this working by using DBEXISTS_PROP <> "TRUE" since the QUERY returns a TRUE value if the DB is installed. Thank you for all the help. :)
You are always welcome! :)
Glad I was able to assist.
