MasterOfDesaster
Dialog with 2 different folder to select
Hello, dear community,
i am new here and have to solve the following problem :
We want to have a dialog, where the user can select 2 different folders (Location of SQL Data/log file)
The edit fields left to the [...] - Buttons are initialized with a valid path, based on local dialog property.
These local properties are initialized in the dialog init event from a global property.
A click on one of the buttons should perform the following actions :
- Show Folder browser based on path in edit field
- Select another folder
- Write back new path in edit field and (dialog local) property
I failed to get this working, please help :-(
Best regards and thanks in advance, Stefan
Re: Dialog with 2 different folder to select
Hello Stefan and welcome to our forums,
In order to achieve that, please have a look over the following article:
How to browse for a folder at install time
MasterOfDesaster
Hi, Catalin,
i alread had a look at this article, but i think, it does not fit to the given scenario :
In this article the selected path is validated and assigned to the underlying property
bei clicking on the [further]-Button.
This does not work, if i have to select 2 different folders in the dialog before clicking [further]
regards, Stefan
Hello Stefan,
If possible, could you please create a sample project that reproduces this and forward it to me?
Additionally, please give me an example (based on the sample project) of:
- what the actual behavior is
- what the expected behavior is
I'd like to run some tests to better understand your scenario and see how we can manage to accomplish your requirements.
