HobartSimms
Prerequisite property in aip
I'm in a bad spot, in that I need to create prereqs using a custom search, on the fly during build automation. The prereqs change frequently in both count and options (windows updates).
Unfortunately, I'm not finding where CLI or powershell can do this for me.
That leaves me with modifying the AIP file - definitely not my first choice in approach.
In the prereq XML, I'm trying to understand the significance / use of the "Property=PreReqSearch..." variable.
I'm assuming it looks like this from use and abuse of copying prereqs between releases.
from aip
from aip
I would much rather go the CLI / powershell route, but the options I need are not available (search based on results of custom script).
Thanks.
Re: Prerequisite property in aip
Please note that you can create a search for your prerequisite based on a custom executable (BAT files included here as you can launch cmd.exe):
If this is not what you want to achieve, then please give me some more details so I can further assist.
HobartSimms
Yes, we've been using it that way for many years. However, that requires me to go in and make manual changes through the AI GUI every time a prereq changes (which is a lot). That doesn't mix well with build automation. Unfortunately (and AFAIK), the CLI only offers these limited options:
{FileVersion|RegSubKeyEnum|RegValue|ProductCode|UpgradeCode}
for the search type in a prereq. If this is not correct, please let me know the CLI (or powershell) workflow for creating a new prerequisite with a custom executable search option.
Thanks!
We already have on our TODO list of improvements adding prerequisite support for PowerShell automation.
I will specifically mention in that ticket that we should also add the "Custom Executable" search criteria.
HobartSimms
Thanks, I'll look forward to that in a future release.
You are always welcome!
This improvement has been added in version 22.9 of Advanced Installer, released July 23rd, 2025.
