the gridlock
Freeze program?
Hi.
I am using version 19.4 and the error I am getting is the following:
in the files, folders and shortcuts tab select add files
when the dialog box appears type in searchbox filter .dll to filter files. (same folder)
then select the filtered dll files.
but now the program freezes not working.
Thanks!
Re: Freeze program?
I've tested your scenario, but I cannot reproduce the behavior.
Are you able to reproduce this on multiple machines?
On my machine I have only the "All files (*.*)" option:
all files.png (141.31 KiB) Viewed 3588 times
Can you tell me how do you select the "dll" filter mode? Could you please give me some more details (maybe exemplify with some screenshots)?
the gridlock
Re: Freeze program?
Hi Liviu,
i tried using windows10 and it is working. before that i used win11 and got error.
I'll come back if I have this problem again.
Thanks!
Re: Freeze program?
Sure, let us know if the issue happens again.
I've also tested this on Windows 11.
