criticalxi
Custom Theme Images
I am trying to use custom images for my installer. Locally it seems to work fine if I replace the images found in "C:\Program Files (x86)\Caphyon\Advanced Installer 20.0\themes\classic\resources\variations\aero" with my own. Even building the install and running it locally, the installer has my custom images. But zipping up the install and giving it to a friend to test it, it has the default installer images.
How would I adjust this so that other people using the install get my custom images with the installer?
Re: Custom Theme Images
Can you please use our predefined support to change the pictures? Just go to the Themes page --> Customizable Images section:
themes page.png (226.97 KiB) Viewed 3470 times
and see if that helps?
Otherwise, can you please send us the .AIP (setup project) file and a download link for your setup package by email to support at advancedinstaller dot com so we can further test and investigate this?
