mcseforsale
Several issues with Air Flat theme
Issue 1 is that in the license dialog in the editor, the borders look fine. However, when compiled and executed, the top border takes over an inch of real estate.
The second issue is that we would like to change the color of the borders in this theme. Is this possible?
AJ
Re: Several issues with Air Flat theme
Hello Aj,
Not quite sure I fully understand the issue here.
If possible, could you please try to forward me some screenshots showcasing this?
mcseforsale
I've attached the screenshots.
Thanks!
AJ
Hello Aj,
Thank you very much for the provided screenshots.
I can indeed see what the problem is now.
However, it looks like your theme is a little bit modified (not like the default one), so is it possible for you to provide a sample project that reproduces this? Or perhaps give me the steps that you took in order to modify the theme?
Additionally, does this happen on all machines? Or is it specific to one machine only? If the latter, perhaps it has something to do with the resolution.
mcseforsale
Yes. It happens on all machines with several different video settings. How can I get our projects to you without making them visible to the public?
Thanks!
AJ
Hello Aj,
You can do that by sending the resources (sample project) by email at support at advancedinstaller dot com.
mcseforsale
Email sent. Thanks!
AJ
Hello AJ,
Let's continue the conversation there.
