M.Folte
Best practice: Execute SQL scripts based on version
im currently evaluating AI and am making good progress so far.
However one feature we need for our installer/upgrader to execute SQL scripts based on the already installed version.
We have one init script which is only to be executed for a new installation. That was easy enough to accomplish with the condition
NOT OLDPRODUCTS
. However now we have a list of multiple update scripts which are only to be executed if the installed version is smaller than the version of the script.
The first solution that came to mind is to setup a search that reads the current installed version from the registry. I set up my upgrades so the old version is only uninstalled after the installation of the new version. And in theory it works perfectly well with a condition like
INSTALLED_VERSION < "2.4.4"
However we get problems when we go past single digits versions. This systems breaks once we reach version 2.4.10. The condition
INSTALLED_VERSION < "2.4.10"
won't work because 2.4.10 is actually smaller than 2.4.4 if we compare them as strings.
Is there a way to compare strings as version numbers in the conditioning?
If not I already came up with a workaround. However this workaround would require me to add a new search property for every version like so:
And then use a condition like
VERSION_2.4.2_INSTALLED = ""
. But I feel like I'm missing something and there is a better way to do this.
Re: Best practice: Execute SQL scripts based on version
Hello and welcome to our forums.
Indeed, the properties are compared as strings and they cannot be compared as versions, unfortunately. In this case, the workaround you found, which requires a new search for each script, is the best option.
M.Folte
Hello and thanks for the welcome.
Okay, not a problem at all. The workaround works and will do the trick for us. Was just wondering if there was a better way.
Matthias
Hello Matthias,
Thank you for your follow-up.
Please let us know if you have any other questions.
