MGS
Password box - cut text - gray overlay
Hi there,
I just ran into a problem that is very unlikely to occur, and yet it is there and would be nice to have fixed:
1. In the SQL Connection Dialog, I entered a password and then after trying to CTRL+X a text from the password field a popup occurs (which is nice), and then after clicking into the PORT textfield (or alternatively pressing CTRL+X twice) it suddenly shows a gray overlay on top of the SERVER combobox (which is not so nice).
After hovering over the comobox it turns back into how it should look like:
Do you have any idea how to fix this?
Johannes
Re: Password box - cut text - gray overlay
Hello Johannes,
I've tested your scenario, but I cannot reproduce the behavior.
Can you please send us the .AIP (setup project) file by email to support at advancedinstaller dot com so we can further test and investigate this?
It would be very helpful if you could isolate this problem in a sample project that reproduce this issue so we could test it.
MGS
Liviu wrote: ↑Tue Nov 29, 2022 2:39 pm Can you please send us the .AIP (setup project) file by email to support at advancedinstaller dot com so we can further test and investigate this?
Hello Liviu,
I sent the .AIP project file per email to you. Building and running this .AIP project I could reproduce the issue each time.
In addition, I also sent you the steps to reproduce the issue in a sample project. There I could reproduce the problem only once in a while.
Johannes
Hello Johannes,
We received your email. We will reply to you over the email as soon as we will have a conclusive answer.
This has been fixed in version 20.3 of Advanced Installer, released on January 30th, 2023.
MGS
Hello Catalin,
That's great news, thanks for the fix and for letting me know!
Johannes
You're always welcome, Johannes!
