MGS
Refresh registry search
Hi there,
The registry search values are only set once at startup of the installer, is that correct?
Is it possible to refresh the value of a registry search while navigating through the installer using a custom action or some event?
E.g. those searches:
Johannes
Re: Refresh registry search
Hello Joannes,
Yes, during the "Searches" action group.
Yes, that is possible,
The result of your search is saved in the property that has the same name as the search, e.g.: REGISTRY_KEY_ODBC_DRIVER_17_EXISTS
With that being said, you can use, at a later time in the installation, a "Set property" event that should set the property to a new value.
MGS
Hello Catalin,
Thanks for the fast reply!
That information was helpful. But my question
was misunderstood.
At any place in the installer I need the most recent value of the registry key. So I need a way to refresh the property that was assigned using the registry search (e.g. REGISTRY_KEY_ODBC_DRIVER_17_EXISTS). Luckily, I just was able to solve this myself by using a custom Powershell script where I read the registry key again and then assign the read value to the property using the AI_SetMsiProperty functionality.
Johannes
You are always welcome!
Glad you managed to find a solution.
