fede071
Update Installer with mirror URL does not clean up previous version properly
I set my updater to have a URL pointing to the newest version of our software for when the customer is online and a mirror URL pointing to a local folder for the offline customers.
The offline update seemed to function properly but I noticed that after I update to the newer version both software versions are installed simultaneously (see picture).
Screenshot 2022-11-29 155503.png (57.07 KiB) Viewed 3653 times
How can I make sure that upon update my previous version is being removed properly?
Thank you
Best wishes
Federica
Re: Update Installer with mirror URL does not clean up previous version properly
Hello Federica,
I'm not sure why this happens.
In order for us to further investigate this, can you please forward to us by email to support at advancedinstaller dot com the following resources:
1. the .AIP (setup project) file for the old version
2. the .AIP (setup project) file for the new version
3. an installation log of the upgrade process
