curt.blunt
Pre-req scroll bar
Is it possible we can edit our scroll bar to look more appealing to end users so they know it's a scroll bar? It just looks like a line at the moment and they don't know how to scroll across the pre-req screen to view further details/columns.
Looks like this at the moment
Maybe get it to look like this by default
Curt
Re: Pre-req scroll bar
Hello Curt,
Could you please let me know what theme you are using? I'm afraid I can't really tell from the screenshot.
After doing so, I will try to test whether we can work this around and, if not, I will create an improvement ticket.
curt.blunt
I am using White Surface under 'Surface' themes
Curt
Hello Curt,
This is quite strange.
Did you modify the theme in any way? I'm asking this because I have tested this just now and here how's the scroll bar actually looks on the "WhiteSurface" theme:
Hello Curt,
After further testing, it looks like this actually happens if you are using Windows 11.
The screenshot from my previous thread is taken on a Windows 10 machine. I had a colleague of mine test this on a Windows 11 and he actually managed to reproduce this.
This is not something under our control, unfortunately, as we simply call it from the installer. You can see the scroll bar is the same in, for instance, Notepad:
image (3).png (12.72 KiB) Viewed 9530 times
image (4).png (17.65 KiB) Viewed 9530 times
