MGS
Feature Selection Tree in OptionalFeatsDlg
I am currently using the built-in OptionalFeatsDlg in order to let the user chose which feature they want to install. When I add additional features, they correctly display. Now I tried to add sub-features to those features. Unfortunately they are not displayed here as can be seen in the screenshot. Optimally they would show in a tree view so the user is able to toggle if they should be installed or not. How am I able to achieve this?
Johannes
Re: Feature Selection Tree in OptionalFeatsDlg
Hello Johannes,
To achieve what you want you should use either the "ConfigureDlg" dialog or the "SetupTypeDlg" one. Using those dialogs the sub-features should be correctly displayed.
If you do not want to display the SetupTypeDlg dialog, you can drag the CustomizeDlg dialog from the InstallModeCustom folder and then delete the SetupTypeDlg dialog.
Let us know if you have further questions.
MGS
Hello Liviu,
Thanks a lot for the help, that worked great!
Johannes
You're always welcome, Johannes!
