Zsolt Kollarits
Component Drag&Drop is not working
We had 2 files (2 fonts) under a certain location and now we added 2 more fonts. Obviously we just would like to have those 4 files to sit in the same component, but we are not able to "merge" the new component into the old one for some reason. Could you please take a look at the attached image and tell us how to make those 2 components into 1?
Zsolt
Re: Component Drag&Drop is not working
Hello Zsolt,
Could you please try selecting, under the "Temp" componenent, any of the fonts --> right click on it --> "Add to List".
Now, in the list, right click on it --> "Move to existing component".
Then repeat the steps for the other file, too.
Hope it helps!
Zsolt Kollarits
Dear Catalin,
Please take a look at my last screenshot, that's the dialog I got and even if I click on (Move only compatibles), nothing happens basically.
I really don't know why the components are not compatible.
Zsolt
Hello Zsolt,
Well, this is quite strange, indeed.
In order for me to further investigate this, could you please provide a copy of your .AIP file by email?
Additionally, please let me know which components exactly are that you want to merge, as I can see in the first screenshot it was "Temp" and now it's "Styles_Fonts_2".
Zsolt Kollarits
Dear Catalin,
Unfortunately I'm not able to send you an .aip in this moment as I completely reverted my changes and started everything from scratch, since then the issue is gone.
As I mentioned to you, my task is to add 2 new fonts to a folder where we already have 2 fonts. During my first attempt I added the 2 new fonts in one-go, so I selected 2 files in Files And Folders area, so they went into the same component. Then I was not able to move that component and merge it with the old font-component. During my second attempt I added the fonts one-by-one and I managed to achieve my goal somehow.
If I see this issue again, I will send you the .aip.
Zsolt
Hello Zsolt,
Thank you for the followup on this!
I am glad to hear everything is working as expected now.
