jmoleary
Can I control the AI App Font Size from its settings?
The font that AI uses for me is tiny. In particular in the Left Pane. It's hard for me to read. Most of the rest of the Windows App I use are OK AI is just too small.
I don't want to increase the windows general font size just AI's. Is there any way to do that? If not I need to turn this into a feature request...
Re: Can I control the AI App Font Size from its settings?
I'm afraid the font might not be changeable, but in my opinion the size is just fine.
Please make sure you do not have the "Compact Left Pane" option enabled, as that indeed makes the names really small.
as opposed to:
