todo1981
First TIme Install VS patch VS maintence
I notice that within the AIP I have all the options (First Time Install / patch / maintence) ,
but I couldn't figure out how to get to them. Every time I run the installation, I get First Time Install.
It is important to emphasize that I do not register the application under WIndows.
Is there a way to run the installation in Patch mode even when the installation does not use Register with windows installer?
Re: First TIme Install VS patch VS maintence
This is the expected behavior. The dialogs defined here can appear only during the first time install or major upgrade process.
The Maintenance dialogs are displayed when you run for the second time your setup or when you click on the "Change" button on the Control Panel. The dialogs defined under the Maintenance section can appear only during the maintenance process (repair, modify or uninstall mode).
The dialogs defined here will appear during a patch installation only. Therefore, these dialogs will be displayed only if you create a patch for your application.
I hope this gives you some guidance! Let us know if you have any other questions.
todo1981
I can't figure out how to get to any of the places marked in red in the picture.
I always get to the first installation. But if I want to go to maintenance? Or to upgrade?
We don't want to prepare separate files for first installation and upgrade. We want those who do not have the software to always receive the updated version, and those who do, can upgrade with the same installation.
Is it possible to use one of the configurations for an upgrade?
Can someone attach a sample file please?
I have already explained this in my previous reply.
The dialogs under the First Time Install section appear only during the first time install or major upgrade process.
For more details, please refer to the Predefined Dialogs
article.
Simply make the desired changes in the dialogs in the First Time Install section.
