CaMat
Instalator disables itself after choosing wrong path
When I change path to non existing by edit, installer notifies about wrong path and disables all controls on it.
You can reproduce this behaviour by selecting non existing disk in path edit in default SetupTypeDlg in Modern Theme. After that, click on a Typical Installation button.
Is there a solution or workaround to this problem?
Re: Instalator disables itself after choosing wrong path
I investigated it and tried to reproduce the behavior, but I was not able to replicate it.
In order for me to further investigate this, could you please create a sample project that reproduces this and forward it to me together with a test case which I can follow in order to reproduce the problem?
You can attach the sample either here or you can send it by e-mail at support at advancedinstaller dot com.
CaMat
I send sample project by e-mail. Also, I have a gif file presenting problem:
GIF 18.01.2023 08-54-50.gif (641.04 KiB) Viewed 12398 times
I've already replied to you over the email.
It appears this was an issue in Advanced Installer 19.5.
This issue is not reproducible with our latest version. Therefore, can you please build your project using Advanced Installer 20.2.1 and see if that helps?
CaMat
Yes, upgrading advanced installer to version 20.2.1 resolved this problem.
Thank you for your assistance!
You're always welcome!
I'm glad everything is working as expected now.
