a.antonyuk
powershell integration and certificate from azureKeyvault
In advinst it is possible to use certificate from azurekeyvault,
and password from keyvault in azuredevops as - SetAzureKeyVaultSecret ...secret...
When you run advinstGUI it asks for password automaticaly.
Is it possible to specify this password in powershell integration?
Re: powershell integration and certificate from azureKeyvault
I'm afraid we do not have support for this in our PowerShell automation and this is because the Client secret is not stored in the project file.
However, we have support to set this from the command line.
When using Advanced Installer from command line, you can set the Client secret using the following command: SetAzureKeyVaultSecret
Due to the fact that the Client secret is not stored in the project file, SetAzureKeyVaultSecret command can be used only from a .AIC command file.
You can find details about the command file on our Executing a file of commands
article.
