SZLMCL
Automatize installer creation with PowerShell
I have an existing AI installer.
I would like:
1. Increase the version with 1 (generate new guid).
2. ReBuild the installer.
3. Save the project file.
with PowerShell.
This is possible? or there are another ways to automatize this tasks?
Thank you!
Re: Automatize installer creation with PowerShell
Yes, that is possible.
In order to achieve that, please proceed as it follows:
$advinst = new-object -ComObject AdvancedInstaller
$project = $advinst.LoadProject("C:\Users\Catalin\Desktop\Your Application.aip")
$prodDetails = $project.ProductDetails
$prodDetails.Version = "1.0.1"
$project.Rebuild()
$project.Save()
SZLMCL
This is amazing, than you very much. It works!
That is also possible to automate the build of "Updater" project?
Thank you!
Yes, it would be possible to edit the Updates Configuration File, through the IUpdatesProject interface.
This is quite similar with what we've previously done.
SZLMCL
Thank you!
I try write the code, but my first command will not work. :-)
1. Delete all existing updates:
foreach ($iupdate in $project.Updates) {
$project.RemoveUpdate $iupdate
Throws error:
+ $project.RemoveUpdate $iupdate
Unexpected token '$iupdate' in expression or statement.
+ CategoryInfo : ParserError: (:) [], ParseException
+ FullyQualifiedErrorId : UnexpectedToken
Do you have any idea what I making wrong?
Thank you!
SZLMCL
Sorry I have a mistake with PS syntax, now works.
SZLMCL
Finally I succeed with this. I post my code, probably help for anyone.
The only thing that I cannot find in object model is the updates.txt file location. Can you help me please how can I get this? Thank you!
# Delete all update definitions
   $delres = $project.RemoveUpdate($iupdate)
Write-Output "Előző frissítési beállítások törlése befejeződött."
# Add new project
$folder = "a:\INSTALLER"
$latestInstaller = (Get-ChildItem -Path $folder | Where-Object { $_.Name -like "*XY_Setup*.exe" } | Sort-Object LastWriteTime -Descending)[0]
$newres = $project.NewUpdate("Update",$latestInstaller.FullName)
if ($newres) {
	Write-Output "Új telepítő sikeresen hozzáadva."
	$project.Updates[0].Properties.MainUrl = "https://xy.blob.core.windows.net/installers/download/" + $latestInstaller.Name
	Write-Output "","Beállítások",""
	Write-Output $project.Updates[0].Properties.MainUrl
	$date = Get-Date
	$day = "{0:dd}" -f $date
	$month = "{0:MM}" -f $date
	$year = "{0:yyyy}" -f $date
	$project.Updates[0].Properties.ReleaseDate = "$day/$month/$year"
	$project.Updates[0].Properties.DisplayName = $project.Updates[0].Properties.DisplayName + " - " + $projversion
	Write-Output $project.Updates[0].Properties.ReleaseDate
	Write-Output $project.Updates[0].Properties.DisplayName
	$project.Updates[0].ReleaseNotes.BugsFixed = $null
	$project.Updates[0].ReleaseNotes.Description = $null
	$project.Updates[0].ReleaseNotes.Enhancements = $null
	$project.Updates[0].ReleaseNotes.Features = $null
	$project.Updates[0].InstalledDetection.Options.Search64BitLocations = $true
	$project.Save()
	$project.Build()
} else {
	Write-Output "Hiba történt az új telepítő hozzáadása közben."
Thank you for your followup on this and for sharing the code with us.
I am sure this will be helpful for other users facing a similar scenario. :)
Regarding your last question, I'm afraid I'm not quite sure I understand it. The updates.txt file should be built relative to the "Updates Configuration File" project.
