intactfw
AI does not create MSI log directory
Hello!
Our company has recently updated from Advanced Installer 19.3 to the newest version 20.3.1. We have found a breaking change between these versions regarding log files.
A setup built with v20.3.1 does not create a log directory when using a MSI bootstrapper option like this:
/L*V "[TempFolder]\[|Manufacturer]\[|ProductName]\installlog.log"
Instead the setup crashes if the above directory does not already exist. Manually creating such a directory fixes the issue, but is inconvenient. We have now changed our log directory to
/L*V "[TempFolder]\[|Manufacturer]-[|ProductName]-installlog.log"
to mitigate the issue.
Could you please fix this in an upcoming version? Thank you for your help.
Re: AI does not create MSI log directory
The folder must exist before the installer is launched. Also, the installer must have write permission to this folder.
I'm afraid this is the default behavior of Windows Installer. Please note that the command line support to create the log file is handled by Windows Installer, which is designed by Microsoft. Windows Installer is not able to create a new directory for the log file.
Windows Installer simply cannot create folders from the log command before the setup is launched.
There is nothing we can do to control this behavior, because it is handled by Windows Installer.
You can also see that on the MSFT article here: https://learn.microsoft.com/en-us/windo ... ne-options
log path.png (21.96 KiB) Viewed 6019 times
Please let us know if you have any other questions.
intactfw
Hi Liviu!
I am confused that this seems to be the default behavior, since setups that we have created using Advanced Installer 19.3 did create these directories without any further actions or issues. This is why we thought that the upgrade from 19.3 to 20.3.1 introduced a bug. Thank you for your response :D.
You're always welcome!
This is quite strange as I've tested this with Advanced Installer 19.3 and the folders are not created if they don't already exist.
Can you please send us a sample project regarding this (when the folders are created by the log command)?
You can attach the sample either here or you can send it by e-mail at support at advancedinstaller dot com.
