asif0012
How to use PowerShell script or custom executable before installing prerequisites to verify the launch conditions
I want to add launch conditions before installing the prerequisites. I can do that using "Check launch conditions before searching for prerequisites" option. But I need to perform a custom search for the launch conditions, which is not possible with the predefined support in Advanced Installer. However, I can conduct the custom search using a PowerShell script or custom executable.
How can I run a PowerShell script or custom executable before installing prerequisites to verify the launch conditions?
Re: How to use PowerShell script or custom executable before installing prerequisites to verify the launch conditions
If you want to run a custom action before installing your prerequisite, you could use the following option from the "Prerequisites" page --> "Setup Files" tab:
Please note, however, that the above option only works for "pre-install" prerequisites.
asif0012
I need to use the "Check launch conditions before searching for prerequisites" option because I have some prerequisites files in my installer. I want to stop installation using "Launch Conditions" before the prerequisites installation.
Suppose I use a PowerShell script and save the result in an Installer property. Will I be able to use it in the "Launch Conditions"? Is it possible to execute the PowerShell script before the "Launch Conditions" validation?
"Check launch conditions before searching for prerequisites" option:
"Check launch conditions before searching for prerequisites" checkbox
Screenshot 2023-02-12 172254.png (246.41 KiB) Viewed 9945 times
In the attached AIP file, PowerShell script execution doesn't happen before the "Launch Conditions". So, it doesn't prevent the installation.
Check Lanuch Condition.aip
Check Launch Condition
(24.81 KiB) Downloaded 308 times
There's a bit of a "sketch" here.
Normally (e.g. feature-based prerequisite), yes, but I'm not quite sure about the prerequisite being pre-install.
For feature-based prerequisites, you could achieve that by scheduling the custom action before the "Paths Resolution" action group (in which the launch conditions are evaluated):
The problem in your case is that you have the prerequisite scheduled as "pre-install", meaning the check is actually done before the execution of our custom action. Basically, in this case, we can not schedule the custom action before the launch condition is actually evaluated.
That being said, please move your prerequisite to "feature-based" and this should work just fine.
