mli04
The text on the uninstall prompt dialog box is incomplete
Hi Team,
When my installer uninstalls it shows the following dialog, at the resolution of 1920*1080, the left side of the text is incomplete, you can see that the left side of the character t in the text [temporary] is incomplete.
I want to adjust the position of this dialog Chinese this book, but I can't find it in my aip project file, this dialog seems to be from a template, thank you very much for any help.
Andrew
Re: The text on the uninstall prompt dialog box is incomplete
Hello Andrew,
I investigated it and tried to reproduce the behavior, but I was not able to replicate it.
Can you please send us the .AIP (setup project) file and your OS version and build number by email to support at advancedinstaller dot com so we can further test and investigate this?
