alco
Is it possible to link a hyperlink control to a checkbox
I have a wizard page that contains two checkboxes with two hyperlinks, but they are not 'linked' in such a way that clicking on the part that says "I have read and accept the" should toggle the checkbox state (checked or unchecked).
It'd be a great UX improvement if the default click behavior of checkbox text is replicated in the hyperlink so clicking on the non-hyperlinked text affects the checkbox. Is this possible?
Re: Is it possible to link a hyperlink control to a checkbox
Hello Albert,
Thank you for your input on this!
It would indeed, as you mentioned, be a great UX improvement.
I will discuss this with our dev team to see whether this can be implemented or not (because right now I am not quite sure).
