the gridlock
Interface problem?
let's say I have 10 projects (tools) for 10 peoples.
these project are of the same type so the project will have the same product name (but different assembly).
my problem is when opening files/recent they are all the same. I won't know whose project this is..
this is annoying.
is it possible to consider using files .aip name instead of the product name for list recents file?
Also , is there a way to clear all recent project names?
Thanks you!
https://www.dropbox.com/s/j1epdad8tyeqb ... 1.png?dl=0
Re: Interface problem?
I have added this on our TODO list of improvements and hopefully it will be implemented in a future version of Advanced Installer.
Thank you for bringing it to our attention!
And yes, it is possible to remove a project.
You can do so by opening Advanced Installer --> "Open":
the gridlock
Thanks! it's worked.
You're always welcome!
This improvement has been added in version 20.6 of Advanced Installer.
the gridlock
Nice :)
Thank you. exactly what I expected.
You are always welcome! :)
Return to “Feature Requests”
