For an Enterprise or higher project type, you can change the logo from the
Images tab:
- applogo.png (57.46 KiB) Viewed 3170 times
While using this theme, Windows current theme (dark/light) is automatically detected and applied to your installation. Based on that, you need to change both the
AppLogoIcon and
AppLogoIconDark logos.
For the Professional project type, we do not yet have the option to change the logo on the Preview tab, as with the other themes. This enhancement is currently being worked on and will be added in our next release.
Until then, you can go to the following path:
C:\Program Files (x86)\Caphyon\Advanced Installer 20.4\themes\appinstaller\resources\variations\default
and replace the
applogo.png and
applogodark.png files with your own pictures.
