AquaComm
Install shortcut to specific folder.
As you can see I am trying to add this shortcut here:
Unfortunately it keeps getting installed in the root folder.
I've sent the aip file to support.
Re: Install shortcut to specific folder.
Hello Glen,
Starting with Win 10, the OS only create a single folder, you cannot have multiple folders created in the Start Menu.
Also, the folder is being created only if there are more than 2 shortcuts created in the related path. Otherwise, the shortcut is created directly under the Start Menu.
You must have at least 2 shortcuts added to your custom folder (MyCourts). The MCLibraryManager subfolder will not be created, as this is the default behavior of the operating system.
I hope this is helpful!
