My product constitutes of 2 sub-products which I install using single msi. Both the subproducts XA and XB have their own readme.txt. The installation folder for both the reame.txt files are different. but when I run the msi, windows installer copies the same readme.txt in both the folders.
Is there some rule that not more than one readme.txt can be allowed in the same product. When I change the names, it works fine.
Please suggest as I do not want to change the name of readme.txt.
P.S. Both sub-products also have their own setup.ini which are successfuly copied to respective locations by the windows installer.
regards,
manish
