I'm afraid that the ScrollableText control is controlled by Windows Installer and it renders text differently than Word/Wordpad.
You can either try making your tables smaller or you can use our
HtmlHost control. However, please note that the HtmlHost control requires the Enhanced User Interface, which is handled by our EXE Bootstrapper (it will change the package type to EXE).
For the HtmlHost control approach, you need to convert your .rtf file to .html file.
For example, the below html table:
<!DOCTYPE html>
<html>
<head>
<style>
table {
font-family: arial, sans-serif;
border-collapse: collapse;
width: 70%;
td, th {
border: 1px solid #dddddd;
text-align: left;
padding: 8px;
</style>
</head>
<body>
<h2 align="center">HTML Table</h2>
<table align="center">
<tr>
<th>Priority</th>
<th>Response Requirements</th>
<th>Resolution Requirements</th>
</tr>
<tr>
<td>Priority 1</td>
<td>We will respond within eight (8)
business hours of an initial error
report.</td>
<td>Final resolution must be provided
to Licensee within two (2) business
days of the initial error report
(considering the error cause IS
identified)</td>
</tr>
<tr>
<td>Centro comercial Moctezuma</td>
<td>Francisco Chang</td>
<td>Mexico</td>
</tr>
<tr>
<td>Ernst Handel</td>
<td>Roland Mendel</td>
<td>Austria</td>
</tr>
<tr>
<td>Island Trading</td>
<td>Helen Bennett</td>
<td>UK</td>
</tr>
<tr>
<td>Laughing Bacchus Winecellars</td>
<td>Yoshi Tannamuri</td>
<td>Canada</td>
</tr>
<tr>
<td>Magazzini Alimentari Riuniti</td>
<td>Giovanni Rovelli</td>
<td>Italy</td>
</tr>
</table>
</body>
</html>
will be displayed like this:
- htmlhost.png (41.49 KiB) Viewed 2188 times
The table will be resized automatically.
You can either upload the .html file to your website and choose the URL source type for the control or you can use the File source type. To do this, you need to add your .html file as a temporary file on the Files and Folders page and then select it using the [...] button.
- temporary.png (102.25 KiB) Viewed 2188 times
Attached you can find a sample project with the above implementation.
