Fellerson
Add Path system environment variable
Hi dear
i would like add a new environement variable in System Path
is it the right way to do it like below ? What should i put as component ? ty
MicrosoftTeams-image (5).png (7.8 KiB) Viewed 4245 times
Re: Add Path system environment variable
That is indeed the correct way to achieve this.
Regarding the component, you should choose a component that is always installed so the env variable will always be added.
If you are not familiar with what a component is, I would suggest reading the following article from Microsoft:
Windows Installer Components
