kerenor
Error starting a new process from the main app
This is most likely an MSIX question and not an Advanced Installer question, but regardless I'd appreciate your help.
I have a c# app that needs to start a new process that runs a .bat file. This fails with the error
Unable to start C:\Program Files\WindowsApps\App.E_1.0.0.67_x64__5c1j8dm4w74ew\utils\runtime_analyzer.bat. Exception received: System.ComponentModel.Win32Exception (1726): The remote procedure call failed.
   at System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo)
   at System.Diagnostics.Process.Start()
   at Worker.ExecuteAsync(CancellationToken stoppingToken)
I opened PowerShell in that MSIX app using Hover (many thanks!) to see if I can run the batch file from there and saw that directly running the batch file works:
PS C:\Program Files\WindowsApps\App.E_1.0.0.67_x64__5c1j8dm4w74ew> .\utils\runtime_analyzer.bat
 [... does whatever it needs to do, but in this process]
But indeed starting a new process doesn't:
PS C:\Program Files\WindowsApps\App.E_1.0.0.67_x64__5c1j8dm4w74ew> Start-Process .\utils\runtime_analyzer.bat
Start-Process : This command cannot be run due to the error: The remote procedure call failed.
At line:1 char:1
+ Start-Process  .\utils\runtime_analyzer.bat
    + CategoryInfo          : InvalidOperation: (:) [Start-Process], InvalidOperationException
    + FullyQualifiedErrorId : InvalidOperationException,Microsoft.PowerShell.Commands.StartProcessCommand
Needless to say, outside of MSIX context starting a new process does work.
Would appreciate any ideas on what am I doing wrong and how to start a new process from a batch file inside MSIX (Starting new exe processes is possible, from other tests done)
Many thanks!
Keren
Re: Error starting a new process from the main app
Hello Keren,
That might be a MSIX limitation, as you do not have access from your MSIX app outside of the container - due to security reasons.
If possible, please allow me some more time to discuss this with our colleagues and I will followup on this thread as soon as I will have more information.
Thank you for your patience!
Hello Keren,
So I've been testing this and it looks like this works just fine.
Here would be the C# code that launches the batch file:
    class Program
        static void Main(string[] args)
            ProcessStartInfo psi = new ProcessStartInfo();
            psi.FileName = @"C:\Users\Catalin\Desktop\hello.bat";
            psi.CreateNoWindow = false;
            psi.WindowStyle = ProcessWindowStyle.Normal;
            Process p = Process.Start(psi);
            p.WaitForExit();
After I install the MSIX and the application is launched (launchbat.exe), the BAT file is executed as expected.
Could you please make sure your MSIX has the "FullTrust" capability? You can check this in "Capabilities" page.
kerenor
This is interesting, thanks Catalin for your response!
My package indeed has fullTrust capability, and in fact we have very similar c# code, but in our case it also sets the ProcessStartInfo to use shell execution, like so
            psi.UseShellExecute = true;
Perhaps that is the cause of this behavior. If I have time I will try it without that and tell you if it works.
Do you know if perhaps that is some limitation with MSIX apps? (this flag differentiates between starting a process with ShellExecute vs CreateProcess)
Keren
You are always welcome, Keren!
To be fully honest with you, I am not quite familiar with that so I can not say for sure whether it is the cause of this or not.
Please keep me updated if this works without that line added.
kerenor
Thanks for your support
just updating that it indeed runs without ShellExecute. Interesting!
That is quite interesting, indeed.
