leeroy
Empty Command Line Parameters Merged Together
Hi, we are running an Inline Powershell Script and passing in parameters, but when a user passes in empty parameters on the command line the values are munged together in an unusual way.
Command:
msiexec.exe /i installer.msi /qn HP_URL="" IDS="123456"
Powershell Inline Script:
Parameter values:
-cfPath "[APPDIR]/Config.json" -tkURL [TK_URL] -hpURL [HP_URL] -ids [IDS]
Params (cfPath and tkURL are calculated from other scripts): :
Param($cfPath , $tkURL , $hpURL , $ids )
$hpURL = "IDS=123456" <-- This has been munged together
$ids = ""
However if HP_URL is provided a value other then empty string it works fine.
Re: Empty Command Line Parameters Merged Together
If possible, could you please create a sample project that reproduces this and forward it to me?
I'm afraid I wasn't quite able to reproduce this on my end.
leeroy
I made a simple install. After you build it just run it like the following.
msiexec.exe /i paramTester.msi /qn BAR="" BAZ="2041860278"
Output:
The baz param ends up in the bar param.
Your Application.aip
Sample Application
(15.83 KiB) Downloaded 285 times
I have tested this using the AIP file you provided, but I'm afraid I'm not able to reproduce this:
leeroy
I wonder if you ran this in a regular command prompt, not PowerShell. I believe this only occurs in PowerShell.
Kind regards,
Lee
Hello Lee,
There shouldn't be any differences if you run the setup from a PowerShell or a CMD shell.
I have tested this with PowerShell and the results are the same:
