ultematum091
Issue with Advanced Installer MSIX installation not installing required dependencies
I have been using Advanced Installer to create an MSIX installation package for my application, which is distributed through the Microsoft Store. However, I have noticed that the installation package does not install the required dependencies during the installation process. Specifically, I need the .NET Framework 4.8.0 to be downloaded and installed when the application is updated.
I have tested the same installation package with MSI installer for the App Center, and the dependencies are correctly installed. However, when the application is updated or downloaded from the Microsoft Store using the MSIX installer, the dependencies are ignored.
Could you please help me find a solution to this issue? I need the MSIX installation package to download and install the required dependencies automatically during the installation or update process, like the MSI installer does for the App Center.
Thank you for your help.
Re: Issue with Advanced Installer MSIX installation not installing required dependencies
Please note that "Prerequisites" are not supported in MSIX.
Instead, for MSIX we have something called "Dependencies", as you mentioned.
MSIX Applications: Handle Prerequisites by Declaring Dependencies in MSIX
Please have a look over the above article which explains in detail how this works.
ultematum091
I can't install a dependency for .net framework 4.8 or another version, because I need to either specify an MSIX file or an already installed application from the MS Store, but the .net framework only includes in .exe and does not install in the directory where the applications are located MS Store, can you explain how to install such a dependency.
For now, I'm afraid that I do not have a solution.
As you mentioned, dependencies should either be an MSIX package or available to be downloaded from the Microsoft Store.
I have added this on our TODO list and our dev team will further investigate this.
Once I will have more information, I will update this thread.
ultematum091
Catalin wrote: ↑Wed Apr 19, 2023 2:01 pm Hello,
Hello, you have any updates?
I'm afraid not.
As previously mentioned, I will update this thread once I will have more information.
