joefio
Call exe with command line arguments
I have a file config.exe that is required to run at the end of the installation in order to configure the installed program. Based on the documentation it seems that the "Launch installed file" custom action should accomplish this. However, the config.exe requires cmd line arguments passed to it. I see that in the properties under "Launch installed file" there is a field "Command Line:", however I'm not sure exactly how this works.
In the NSIS installer I used previously, I would call "config.exe /i [path]". Would I put "config.exe /i [path]" in the command line field? Or would I just put the arguments here "/i [path]"?
I would appreciate any help here. Thanks
Re: Call exe with command line arguments
The EXE is basically already given as an argument, so you would need to only pass the "/i [path]" part.
Please make sure you add the custom action after the "Add resources" action group (this is when your files are copied on the disk).
