apajovejohn
Disable Next Button until ListBox entry is SELECTED
I'm trying to ensure that the user can't click Next until an entry is clicked in a dynamically created ListBox. The ListBox is populated by a PowerShell script custom action (to list certificates for the user to pick for binding to the IIS websites we're creating). This all works great, but there's a "bug" that I can't work past where the user can elect to not click an entry in the displayed list and then the installer fails.
Is there a way that I can disable the Next button until the user clicks a certificate? I've tried setting AI_LISTBOX = "" disable and AI_LISTBOX_DATA <> "" Enable but I think the ListBox always has data once it's been populated, so this doesn't appear to work.
Re: Disable Next Button until ListBox entry is SELECTED
I just tested this with a sample project and everything worked as expected.
listbox control.png (34.65 KiB) Viewed 4577 times
The ListBox control is populated with the available drives on the computer, through a PowerShell script.
On the Control Conditions of the Next button you need to pass the property name of the ListBox control:
control conditions.png (15.83 KiB) Viewed 4577 times
listbox property.png (59.67 KiB) Viewed 4577 times
Please find attached the sample project.
I hope this is helpful!
apajovejohn
Liviu, I'm really grateful for your support.
I got it working as you describe, it was not working previously as I had fundamentally misunderstood how to use the AI_LISTBOX_DATA property and was using that as my actual LISTBOX property, it worked, but having a MY_LISTBOX_PROP which I can then check the data of after pushing info into it from AI_LISTBOX_DATA custom action was the missing piece.
Thanks again
john
You're always welcome, John!
