Iangb
Folders are still going to APP DIR
Hi, people!
I am building an installer for a game, and set the files to go to "C:\Program Files (x86)\Company name\Game name". The problem is that my saved games still are going to some folder inside APPDIR (or APP Data) folder. How do I change that and make my folders go to the folder mentioned above? How do I retire the authority of APP DATA (APP DIR)?
Thanks!
Re: Folders are still going to APP DIR
I'm not sure why this happens.
Does this happens during an upgrade or a first time installation?
Can you please send us the .AIP (setup project) file and an installation log by email to support at advancedinstaller dot com so we can further test and investigate this?
You can create an installation log by launching your setup package with a command line like this:
msiexec /i setup.msi /L*V "D:\installLog.txt"
when using an MSI package type, or a command like this
setup.exe /L*V "D:\installLog.txt"
when using an EXE package type.
Iangb
Hey, Liviu, thanks for your reply.
This happens during the first time installation. When I first launch the game, it will create a directory in "AppData", the path goes like this:
C:\Users\USER\AppData\Local\VirtualStore\Program Files (x86)\3DO
Sure, I'll do that.
Where do I put that code you mentioned? How do I do that?
Thanks!!
Please have a look at the How do I create an installation log?
article.
You just need to open a Command Prompt (cmd.exe) and use the command line provided above.
