frankschn
Advanced installer Express
Hello Community,
I actually have a fairly simple project in front of me, but I can't do it.
Base:
- actual Version Advanced installer express
- myapp.exe and myapp.pdf
- Code signing certificate
I want to create a msix package with following installation paths
C:\Program Files (x86)\myapp\
C:\ProgramData\myapp\
all my attemps failed... no folder is created
is it even possible with the free version advanced installer express?
regards Frank
frankschn
Re: Advanced installer Express
or do I have to create a msi first?
Hello Frank and welcome to our forums,
Not quite sure why you would need an MSIX, but yes, you can create an MSI for that - it seems quite easy.
However, please note that the Express version can not create MSI packages (it is intended only for MSIX).
Now, coming back to your issue - the Windows OS will automatically install MSIX packages in the following location:
%ProgramFiles%\WindowsApps
4. Install Location
Please give me some more details about your scenario and hopefully I will be able to assist.
frankschn
Hello Catalin,
thanks for your answer.
for my really simple project, a msi is enough for me.
I downloaded the normal version of advanced installer (20.6) and already created a msi package. :D
A simple installer project with project language German is enough for me.
My next problem is, that with simple installer projects, only English (United States) can be selected. do i need a language pack or is that not possible in the freeware version?
why doesn't my Product Name appear here, can I change it instead of 25d2457.msi ?
regards Frank
frankschn
I solved the problem with the file name in the uac
i forgot to use /d command line argument with signtool
Hello Frank,
Awesome, I am glad to hear everything is working as expected now! :)
