h.hasenack
File association mangled in explorer "open with" menu
Heloo,
AFAIK I do not specifically set a different file other than this:
after installion on a clean machine, the file association works as expected. BUT ...
The "Open with" menu looks like this:
Upto now I seem to be unable to fix this, help is appreciated. Currently using Advanced installer Version 20.6 (7C7B154C)
But the problem appears to be in there for quite some time already, so expect this to be an AIP project issue.
I am not sure, but it might be related to installing 2 versions of my software next to eachother (AKA keep old version) on my clean test VM. I installed the older version of my app first, and next the newer version.
TIA,
Hans Hasenack
Kind regards,
Hans Hasenack
S&G Asset Management
Netherlands
Re: File association mangled in explorer "open with" menu
Hello Hans,
I investigated it and tried to reproduce the behavior, but I was not able to replicate it.
Can you please send us by email to support at advancedinstaller dot com so we can further test and investigate this, the following resources:
1. the .AIP (setup project) files for both versions
2. an installation log
3. a download link for your setup packages (the old version and the new version)
4. your OS version and build number
h.hasenack
DOne! :geek:
Kind regards,
Hans Hasenack
Netherlands
Hello Hans,
Let's continue the conversation there.
